Сообщение от KaKu
Имя
А про VIO POV HD можешь что нибудь рассказать?
VIDEO - 1080p HD Video
Resolution/Frame Rates: 1080p/30fps, 1080p/25fps, 1080p/24fps, 720p/60fps, 720p/50fps, 720p/30fps, 720p/25fps, 480p/30fps, 480p/25fps
Video Codec: H.264
Video Container: MPEG-4
Exposure control: Automatic Exposure Control and White Balance
IMAGING HARDWARE - Advanced Native 1080p CMOS Sensor
Sensor: 1/2.7” HD CMOS sensor, 3.0 µ meter pixel size
Dynamic Range: 69 dB
Sensitivity: 3300 mV/(lux-sec)
Operating Temp: -20°C to +60°C (-4°F to +140°F)
Processor: 32 Bit ARM Microprocessor, 10 Bit Image
OPTICS - Widest 1080p FOV On The Market
Aperture: f/2.0, Relative Illumination @ Full Field 90%
Focus Distance: .7m - Infinity
Field Of View: 142° (1080p), 95° (720p)
AUDIO - Built In Mic
Audio Codec: AAC
Mic Type: Monaural Omni-directional Cable-mounted, -40dB sensitivity at 1kHz
Resolution: 16 Bit Half Duplex
Sampling Rate:16kHz
SNR: 80dB
Speaker: Monaural 8 ohm Mylar, 0.7W Max
DATA HANDLING - 32GB SDHC
Max Storage Media: 32GB SDHC
File Functions: Record, Playback, Delete
I/O Ports: SD Card Slot, USB 2.0 High Speed (Mini-B), Mic-In, NTSC/PAL Analog TV /Audio Out (Live Stream Capable)
Record Time: 4.33hrs (1080p 30fps/720p 60fps) 15Mbit/S
USER INTERFACE - Ease Of Use
Image Display: 2 Inch LCD Screen, Resolution 640x320
Navigation Controls: All On Recording Unit, Including Quick Mode Select Keys For Recording, Playback, & Set-Up Modes.
Auxiliary Controls: RF Remote Control With Record, Tag, & Stop Controls
Functionality: Record, Tagging, File Navigation Including Select, Playback, & Delete. Recording Configurable for either Standard Clip, Loop, or Loop and Forward. User-configurable Camera Settings Via Settings Menu Screens.
SIZE & MASS - Lightweight + Compact
Recording Unit: 40mm x 60mm x 167mm, 328 grams (With 4 AA Batteries)
Camera Head: 58 grams
Remote Control: 24 grams (With A27 Battery)
Digital A-V Cable: Approximately 1.5 meter Length, 128 grams
Battery/Runtime: 4 AA Alkaline/2.5hrs (1080p 30fps/720p 60fps), 4 AA Lithium Ion/5hrs (1080p 30fps/720p 60fps)
Нормуль вроде девайс вполне. Но у гопро есть бэкпэки, а тут "пульт" с шнуром этим... Я бы не стал. Но как именно нашлемная камера, может она и удобнее кстати. Просто я гопро воспринимаю как мелкую камеру для всяких сложных ракурсов и на убой, если что. А эта штука доп гимор с креплением, куда этот шнур девать и всё такое...
При том, что экран для гопро докупается или wifi транслятор на айфон например. Гопро по компактности выигрывает.
