Привет всем.
Поздравляйте.. СОБРАЛ!!!!
много фоток тут
FRAME M5 alloy, ORE TT and DT, low center of gravity Enduro FSR frame, forged HT, pierced seattube, sealed cartridge bearings, ISCG mount, two forward shock mounts for geometry adjustment, replaceable derailleur hanger, derailleur guard, 150mm travel
REAR SHOCK Fox DHX Air 5.0, 8.75"x2.5" external rebound, Bottom Control and ProPedal adjust, twin sleeve, 150mm travel
FORK Fox 36RC Talas, 110-150mm, external rebound, high/low speed compression adjustment, 20mm thru axle, alloy steerer
HEADSET Sunline V1 All Mountain Headset
STEM Kore B52 - 661 Stem Bar Diameter – 31-8mm 4 bolt faceplate w/PC logo insert Rise/Length – (0 deg.) 55mmMaterial – 3D forged al 6061
HANDLEBARS Truvativ LE 31.8mm Alloy T-6, Rise options 35mm, width 640mm
GRIPS Sunline Logo Lock On Grips - Thin 2007
FRONT BRAKE Shimano M-965 XTR, hydraulic disc, 8" XT rotor, metallic pads
REAR BRAKE Shimano M-965 XTR, hydraulic disc, 7" XT rotor, metallic pads
BRAKE LEVERS Shimano XT
FRONT DERAILLEUR Shimano Deore Front Derailleur Top Swing M530 34,9mm
REAR DERAILLEUR Shimano XT Rear Derailleur M751 , derailleur protector
SHIFT LEVERS Shimano Deore
CASSETTE SRAM PG980 Cassette 9sp
CHAIN SRAM PC971 Chain 9sp
CRANKSET Shimano SLX Chainset Double M665, 175mm with honeycomb
bashguard
CHAINRINGS 36/22T
RIMS DT Swiss EX 5.1 XC-FR Disc 32 hole
FRONT HUB DT Swiss 340 Disc Front 20mm
REAR HUB DT Swiss 340 Disc Rear
SPOKES DT Swiss Competition Stainless DB
FRONT TIRE Specialized Enduro, 26x2.3", aramid bead, dual compound, 120 TPI
REAR TIRE Specialized Enduro, 26x2.3", aramid bead, dual compound, 120 TPI
TUBES Bontrager Presta
SADDLE Specialized Enduro, 8mm Cr-Mo rails, SL foam
SEAT POST 6061 butted alloy, two bolt setback, 30.9 x 170mm
PEDAL Crank Brothers Candy C
вес в данном комплите 14, 840!
